RCU Forums - View Single Post - Linkage setup
Old 08-31-2006 | 04:21 PM
kregan's Avatar
kregan
Default Linkage setup
I need a little advice on linkage setup.
When I setup my 35% radiocraft I used 1-1/4" SWB arms
on all the surfaces and set up triple rates or conditions with
everything on one 3 position switch.
I had low rates for precision flying, mid rates for testing, and
high rates for 3D... it looked more like a fish out of water
flopping around then 3D!
After working hard on my basic routine for my first contest
(then not being able to attend, long story) I find myself
a lot less interested in 3D and really want to focus one precision
flying.
I feel like I have given up some resolution in my radio at low
rate in order to gain the 3D throws at high rate. I want to go back
and setup the linkage again for precision flying.
I am thinking about setting up the linkage so I can get my present
low rates, but make sure the radio dual rates are at least at 100%
for the low rate, and just use the rest 140% for high rates. Does that
sound right?
A few questions:
1) What would you recommend for a high rate setting on each surface
if I am not concerned about 3D flying?
2) What about low rate settings?
3) I don't like flipping switches during a routine so is it best to set up the
plane so it will snap and spin well and use that as the lowest rate, or
do you use a higher rate for snaps and spins and flip switches?
4) Should I have more down elevator then up ? if yes why?
The plane is a 35% radiocraft Extra with a DA 100. Radio is a Futaba
9C Super.
Thank you for the help.
BTW everything is set up with a Hitec programmer.
