RCU Forums - View Single Post - Cermark Pitts Build/Assembly
Old 08-31-2006 | 08:06 PM
V2PLUS10
Default RE: Cermark Pitts Build/Assembly
We are nearly there...I like to use Goop to attach the servos to the hatch covers. If you use this method don't just apply the Goop and leave it to cure..the servo will slide with the slightest pressure..keep an eye on things till the Goop sets a bit... I like to minimize the number of servo plugs if I can. So the servo extensions were soldered into the existing servo wire-with fewer plugs there are fewer things that can vibrate loose... I used Dubro ball-end links for all the pushrod attachments. This is the upper wing. Other pictures show the battery location, behind where the bottom wing attach screws are fastened. I needed this location to balance without adding any dead weight to the tail. The other pics show the location of the onboard glow driver and the throttle servo. The rudder and elevator servos are in the tail so the fuselage looks a little empty, except for all those wires everywhere. The model looks pretty good..The Virtual Cockpit from www.wrightrc.com arrived today, so once that nd the pilot are installed, I'll attach the canopy and go flying....!
ID:	516784   Click image for larger version
ID:	516785   Click image for larger version
ID:	516786   Click image for larger version
ID:	516787   Click image for larger version
ID:	516788   Click image for larger version
ID:	516789   Click image for larger version
