RCU Forums - View Single Post - Evader ST Diff problem
Old 08-31-2006 | 09:40 PM
Snipin_Willy's Avatar
Snipin_Willy
Default RE: Evader ST Diff problem
If you set the diff too tight, it'll do that. When the diff is too tight on the standard steel ball bearing, they wont roll on the plates as they should. Instead, they'll slide on the plates making flat surface and sooner or later eating up the main diff gear.
