RE: 1/8th scale B-1B
HI Hustler58,
I am really impressed with your project, i am also doing same on my S Connie project, but wondering why did you used Blue foam instead of white foam, its is my understanding that blue foam is more denced and that is why its heavier in weight compaired to white foam?, other question is, after cutting out all the foam parts what will your next step be, are you planning to sheet the whole airframe with balsa sheeting or going to glass it over the foam....i am at that stage also so wondering my options currently...
Sammy
