vibrations with Saito 82
I have saito 82 mounted on H9 Ultra Stick 82 with 13x8 2 blade prop. I think hole diameter for prop is slightly larger than engine shaft diameter. When I started engine for the first time, there was lot of vibrations.
Do you guys think it is because of larger hole dia. in prop?
What else could cause excessive vibrations?
