RCU Forums - View Single Post - Cermark Pitts Build/Assembly
Old 09-01-2006 | 01:44 PM
V2PLUS10
Default RE: Cermark Pitts Build/Assembly
The Virtual cockpit is installed and the canopy is in place...the model came with screws to attach the canopy, but I used Formula 560 canopy glue instead. I marked the fuselage with a Sharpie fine point pen, as the ink can be removed with rubbing alcohol, and then poked a thousand or so( or maybe a few hundred!) little holes in the covering and into the wood with a pin, where the canopy would contact the fuselage. I'll post pics when the tape is taken off... These pics show the cockpit just prior to attaching the canopy, and also the Pitts logo on the fin that I bought from www.litepilots.com ....
ID:	517097   Click image for larger version
