TopCap pull/pull
The wires are probably binding in the tubes causing the double centering. I suggest going to walmart and in the sporting goods section get some coated stainless leader line that is a slightly smaller diameter than the line you are using now. You can use the collars that come with the leader line to crimp on the leader line in the place of the supplied pull pull wire. This should free up the pull pull system considerably.
