RCU Forums - View Single Post - Linkage setup
Old 09-01-2006 | 08:17 PM
kregan's Avatar
kregan
Default RE: Linkage setup
Are the rates below for aileron and elevator your
maximum available rate? or do you get a little more
if you crank your DR's up to 140?
Do you know how many degrees your servo's are rotating
at those throws?
ORIGINAL: wgeffon
You are absolutely correct in your thinking. 140 ATV / 100% DR's for precision.
My throws are basically this. (Carden 40% 260)
Aileron: 23.5 degrees up and down
Elevator: 12 up and 13.5 down.
Rudder: 30 low (Snaps) 45 high (Hammerheads and rollers)
