RCU Forums - View Single Post - Odd Carb Problem...
Old 09-02-2006 | 12:42 AM
IBrakeForNobody's Avatar
IBrakeForNobody
My Feedback: (16)
Default Odd Carb Problem...
Since I'm the unofficial aircraft mechanic for Sun_Kissed_Girl's planes, I have brought it upon myself to also fix a problem with her Hangar 9 Twist 3D. Its kind of an odd problem, in which when the prop is flipped (to start the engine), the carb closes progressivley until it is completely shut. It closes about 1/16 of an inch every flip. I cannot seem to find the source of the problem as I've checked the pushrod, the pushrod tube (which is glued in), the carb barrel, the linkage where the pushrod connects to the servo horn, everything I can think of. The only idea I have at this point is that there is some radio conflict between the JR 537 servo thats being used for throttle, and the S3004s that are throughout the rest of the plane, although none of the other servos show any problems. Any ideas? [sm=confused.gif]
