are cf shock towers wrth the mony though. wat tuned pipe do you think i should use? i took off the wheels, tank, exhaust and that black thing that the transmitter is on earlier so i could giv it a good clean. slowely feeling more confident in taking it apart. i want to buy sumthing to put on my rush evo just to enjoy fiddling about!!!
btw my brakes don't work very well wat can i do to make them better?
and the left front ball cup keeps coming off after small bumps, anythin i can do to make less fragile? i hav also found the "suspension arm set" (according to book) there are four holes in it i take it that these are used to change the angle of the wheels, is this right and should i change holes? and any1 know what the holes are for at the very top of the front shock tower, as shown in a picture in one of my last posts? are sway bar sets any good on a rush evo? is there a lot of work to do wen installing new engine? should i install blue springs at the rear and yellow at the front?
