RCU Forums - View Single Post - Sig Somethin' Extra Build Thread
Old 09-02-2006 | 08:51 AM
  #196
go-kartowner's Avatar
go-kartowner
Default RE: Sig Somethin' Extra Build Thread
Hey i'm back! I started yesterday and began with putting triangle stock on the rudder. I then hinged the rudder ( but didn't glue it on) and sanded one side with 80 and 220 grit. I will be sanding the whole airframe with these grits and the moving up to 320, 400, 520 and 600. After that it would be the same as rubbing the plane with a piece of printer paper so I'll do that to .I then decided to practice covering on the messed up aileron that I sanded to much(see post 122) I just covered the end with white as that is the color I will be using the least. I will post pics later.
Grey
