RE: Odd Carb Problem...
what engine is it? had an os 45 fsr that the throttle arm was pressed onto the carb barrel and it was not pressed enough for a tight fit and the arm would spin on the barrel,if your carb has a pressed on arm and a spring to help rotate the barrel ,a loose fitting arm in conjunction with the spring would do what you describe
