RCU Forums - View Single Post - vertical fin loose
Old 01-10-2003 | 01:35 AM
Whirley Bird
Default Re: vertical fin loose
Originally posted by JamesHow
Hello everyone. I've been reading alot in here. A world of info on the hobby. I'm building an Avistar trainer ARF for my son and I've got a problem with the vertical fin being loose after it has been epoxied in place. What can I do to make it stable?
.I'm a bit confused here.
If you used epoxy and it took a set the vertical fin is still loose?
Can you move it and see where the movment is coming from?
Is the back of the fuse flexing when you move the fin?
