RCU Forums - View Single Post - GP Super Stearman
Old 09-02-2006 | 10:44 PM
  #541
TOMAPOWA
Default RE: GP Super Stearman
Copied from his post...
"With the stab set at zero, the bottom wing should also be at zero degrees. The engine should be set at minus one degree. The top wing should be set at Minus two degrees."
Negative (minus or "-" ) incidence... not positive (plus or "+" ).
ORIGINAL: Skyventures
What does Doctorgo mean by minus 1 and minus 2 degrees? Does he mean he is putting +2 degrees incidence on the top wing and +1 degree incidence on the engine?
