RE: Combat Wing Conversion
Ok. The 8.4v 650mah NiMH battery pack turns the APC 5.7x3 at 14,900. It turns the Cox gray 6x3 at 12,600. It turns the orange GWS 6x3 at about 14,750.
I have an old Ace analogue Tachmaster II, it's not digital, so I'm reading the needle as best I can. My readings are within 100rpm or so.
As soon as my 9.6v battery finished charging I will re-test. I think it's safe to predict that the APC 5.7x3 will top 15,000 on this battery.
This actually out turns some of my old Babe Bees on 25% nitro, which did around 14,500 the last time I tached them.
Should I try a Cox gray 4.5x2? The problem is, this motor system is a lot heavier than an .020, so that's not a practical prop to use.
