RCU Forums - View Single Post - Combat Wing Conversion
Old 09-03-2006 | 02:06 PM
BMatthews's Avatar
BMatthews
Default RE: Combat Wing Conversion
There's another factor to consider as well. The thrust of the GWS setup looks good until you realize that there's not much pitch speed to work with due to the prop and limited RPM's
I have to suck it back and say that the climb measure is probably the best way to compare performances. Either that or a direct drive motor running the same prop as the engine. If it can turn it to the same RPM then you have the same performance.
