RCU Forums - View Single Post - Cable to use for pull-pull setup??
Old 09-03-2006 | 03:59 PM
mikedsilva
Default Cable to use for pull-pull setup??
hi
hope this is the right forum in which to ask this question:
What sort of cable can i use to fabricate my own pull-pull setup?
Background: i have an excelleron 90 which came with its own cable and fittings. One of the cables broke... i have some fishing trace wire which i used to make a bracing on the tail feathers of another plane a while ago. The cable is rated at 18lbs and is plastic coated. In fact, when compared with the stuff that came with the original kit, it looks almost identical!
I plan to use some small diameter brass tubing as the crimping material.
Does this all sound sufficient?
thanks
MIke
