Thanks all.
Had a bad outing this afternoon. First, the doghouse (which still isn't glued on
) came apart on a tree root and I lost the small door. Walked all over looking for it and gave up. Then, I had taken off the sprocket horn guide to see if it helped keep the grass from building up on it. It did. But, bad move as it threw the track. Not all the way off, but just enough to where it almost sawed though the next to the last side skirt on each side. It happened when the tank was quite a ways away, so I didn't hear it chewing them up.
I did have some fun, though. And earlier I took a flashlight out into the yard and found the door. Whew.
So, don't leave the sprocket horn guide off. The last skirt was up, so I'm not sure if it would have done the same thing with it down. Not going to take it off again. [&o]
