RE: First NITRO boat...engine cooling question....
i recommend that you always run the boat in water for the break in process. if you take the engine out you are not really accomplishing anything because there will be no real world effects like drag which will really make a difference in the performance of the engine. make sure you have a safe way to retrieve you boat in case of a stall or flip.
