ultimate engine mounting
I have built 6 of these, I also have the same engine you have. The best way to me is to mount the engine inverted. The saitos run fine inverted. This way engine sits in the propwash, and you have clean cowl on the sides. If you add a perry pump to the firewall the engine runs better. Also your tank is above the carb. I have used this set up on my first DP ultiy.
