RCU Forums - View Single Post - Combat Wing Conversion
Old 09-04-2006 | 10:54 AM
combatpigg's Avatar
combatpigg
Default RE: Combat Wing Conversion
I'm still not buying the comparison, if you are adapting a glow prop to an electric motor. Reason being, you are handicapping the electric motor if it will turn a thinner E prop with better results. I still believe the best comparison would be with the thrust-o-meter or in the air with a plane that weighs close to the thrust output of the combos being tested.
