RCU Forums - View Single Post - HELI DIRECT LIED - HDX300 Main Gear with Strong Steel Main Shaft for Stock Blade CP
Old 09-04-2006 | 01:47 PM
walleye_gfa
Default HELI DIRECT LIED - HDX300 Main Gear with Strong Steel Main Shaft for Stock Blade CP
Totally the wrong part... read the reply... It wont fit without VAST GREAT manipulation (different pinion, CUT SHAFT BY AN INCH, and redrill hole for shear pin) and NOWHERE in the add does it state what "Steve" said it does. What a bold face misleading lie, not even worth returning. Im more angry they wasted my time anyway.
I WILL NEVER BUY FROM HELI DIRECT AGAIN. IF IT IS GOING TO REQUIRE CUTTING, SHAVING, and REDRILLING THE SHEAR HOLE IT SHOULDNT BE SOLD AS "For the Stock Blade CP".
Ticket status: Open [Close]
Category: Customer Services
Priority: Medium
Printer friendly version
Date: 2006-09-01 00:06:22
E-mail: [email protected]
Message:
It doesnt work at all with the blade cp, this is shameful. Its apparent nobody there has ever tried to put it on a blade, it is simply 100% wrong for the blade. Gear teeth, shear pin size, length of shaft... ITS ALL WRONG.
You should pull htis from the market today, I for one dont trust anyhting now.
Date: 2006-09-01 01:36:22
Message:
Bob,
I sold thousands of these for blade CP owners. It is not 100% exactly same as stock one. This is an upgrade and we wrote on descriptions how many teeth it is. What you need is to move the pinion a little bit closer.
This is not Blade CP parts so It doens't have to be exactly the same. As long as it works on blade CP, it's a blade CP upgrades.
We do not mislead anyone. Read the description.
Best Regards,
Steve
HeliDirect
http://www.helidirect.com
http://www.helidirect.com/product_in...oducts_id=1505
Product Model HDX300-GSC
Availability
Price $14.99
Qty.
Buy Now
Description
These new blue main gear and strong steel main shaft set is designed to replace stock flex main gear and the weak stock main shaft. It is much better than stock main gear and much stronger than stock main shaft. The main shaft is drilled on top to use with stock plastic head. This also allows auto-rotation feature. The high strength plastic main gear comes with pre-assembled one-way clutch bearing. The new main gear is lighter and stronger than stock main gear even with the one way hub and one-way clutch bearing.
Part List
- 1 x Strong Stainless Steel Main Shaft
- 1 x High Strength Plastic Blue Auto-rotation Main Gear 137T
- 1 x Auto-rotation Sleeve
- 1 x Main Shaft Collar
- 1 x One-way clutch bearing
- set screws
Application
Use for these helicopters
- Blade CP
- Honey Bee CP2
- HDX300 helicopters
when installing the auto-rotation sleeve, make sure DO NOT PUSH them into the oneway bearing. It could damage the bearing. Twist it slightly and gently force it into the bearing. It will fit in perfectly.
if you got problem with the main shaft that cannot go through the auto rotation sleeve, use sand paper 600 to sand off the burrs on the shaft if there is any.
Features
- Strong steel main shaft reduces the chance of bending main shaft.
- High Strength plastic main gear 137T
- Very easy to maintenance and replacement
- Very strong and light weight
- Auto-rotation feature
- Great price for great products
