Resolution
Guys, I am working on my IMAC plane, but this question
is valid for pattern as well. The question is about
radio/system resolution.
After setting up a surface to travel thru its entire distance using 140%
ATV (end point adjustment on the 9C screen), does reducing that
travel by DUAL RATES reduce the system resolution, or does it
only reduce travel?
Example:
Elevator servo...
End points set to 140 in both directions.
High rate set to 140% = 32 Degree's of movement up and down.
Low rate set to 65% = 15 degree's of movement up and down.
In the above example do I loose system resolution
on the Low rate setting?
Radio is a 9CAPSuper.
Thank you for the help.
