RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 09-04-2006 | 08:51 PM
  #2790
Neurotex's Avatar
Neurotex
Default RE: Air Hogs Aero Ace!
ORIGINAL: MegaByte-2
Neurotex
That jet looks better everytime I see it. I take it since it running the N20's, its on the modded Rx?
I agree on the props. A good GWS prop could up the trust by as much 20%.
Mass produced props aren't the best. They are usually poorly balanced among other things.
Tony
ARS Software & Innovative Solutions
http://www.falcon1.net/~ars/rcmodels.html
Yes, the N20's are running on the Rx that you did the FET mod to. They run great
and take the extra load no problem. No more worries and well worth it!
Found a block of building foam they use in construction and carved a canopy for
it. Sands easy and it's really light.
I'm going back to making some more props. They're not really that hard once you
get the hang of it. Just takes a little time.
