RCU Forums - View Single Post - Pull cable question
Old 09-04-2006 | 09:56 PM
Rebellion
Default Pull cable question
I'm setting up the elevator pull cable system on my Excelleron 90. For those of you not familiar with this plane it uses a single servo to move both elevator halves via four cables. On the elevator halves I used a longer standoff and drilled the holes for the links as close to the hinge line as possible, or so I thought. Three out of four are near perfect, but one is getting a bit more slack than the others. My question is, what do I need to do to correct this? This is my first time setting up a pull cable system so I'm at a bit of a loss.
Dave
