RE: Nitro models pusher Bobcat?
Papasmurf,
The motor has 633kv and using about 45a full throttle. The ESC is E-Max 60A and the battery is of no name barnd that I got from the factory in China 5s 1p 4000 mah rated at 20-30C. The motor is actually best with an APC 13 X 6 prop, but it looks cooler with the 3 blader. I would like to try 12 X 7 or even 12 X 8 but the shops don't carry any of these sizes. One modification I forgot to mention, I rebuilt the horizontal tailplane as a flat plate instead of using the one in the kit. I feel that the flat bottom section will lift the tail too much while flying and will always cause a nose down tendency. The turbine bobcat has a large upthrust ( the exhaust points down ) but this kit has almost a zero thrustline. Just my 2 cents !!
