RCU Forums - View Single Post - resolution question
Old 09-05-2006 | 03:35 PM
Krysta
Default RE: resolution question
Hi Advent,
Reducing the travel by Dual rates will not reduce resolution enough to see with the naked eye. In fact with the plane in the air, you will notice no difference at all.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Product Development & Support Specialist
Futaba Service Center USA
ORIGINAL: Advent
I have a question on system resolution.
After setting up a surface to travel thru its entire distance using 140% ATV
(in the end point adjustment screen), does reducing that travel by
DUAL RATES reduce its resolution?? Or does it only reduce travel.
Example:
Elevator.
End points set to 140 in both directions.
High rate set to 140% = 32 Degree's of movement up and down.
Low rate set to 65% = 15 degree's of movement up and down.
In the above example do I loose system resolution
on the Low rate setting?
Radio is a 9CAPSuper.
