RCU Forums - View Single Post - Help with Jetronic Brake valve
Old 09-05-2006 | 04:32 PM
bevar's Avatar
bevar
My Feedback: (27)
Default RE: Help with Jetronic Brake valve
Put it on the snap roll switch. When you apply full down, you can unload the main wheels causing a lock up at worst, the least it can do is introduce instability.
I use the snap roll button on my SM F-15 with the Jetronic valve and it works great.
Beave
ORIGINAL: turbinepeter
Tim
Would it help then, if i played around with the 7 point curve??
making the mixing inactive, between min and max elevator??
Regards
Peter G
