RE: glowplu problems
Another unfortunate possibility. You have a bad main bearing sending tiny bits of metal through the engine and distroying your plugs amoung other things. TT uses good japanese bearings but the ball retainers can break and when they do they often rub against the crank and send tiny bits of retainer through the motor. Examine the exhaust residue and the slight glitter will be telltail.
Denis
