RCU Forums - View Single Post - Glues
Thread: Glues
Old 09-05-2006 | 10:55 PM
jinzo
Default RE: Glues
I personally use mostly CA. I will use wood glue when I'm bonding a big surface, such as a fuselage double or wing tip. Obviously, epoxy is used in the places where it is required. I have considered trying a build using exclusively wood glue. While I have developed ways of not getting CA on my fingers, the smell has been starting to bother me a bit, partially because my building space isn't as ventilated as it should be. One of the main things that has kept me from trying an all wood glue build is that I have no idea how I would maintain pressure on the surface when glueing something like wing sheeting, cap strips, turtle deck sheeting and other oddly shaped, curved sheets. Using it to glue ribs, spars, fuselage formers and the like is a no-brainer.
Perhaps if I can find some more helpful information as far as how to evenly weigh down wing sheeting and the like, then I will try building my next plane with wood glue. It is definitely cheaper than CA, which would be nice.
