I'm still trying to dial mine in right now, so maybe Wallnut will step in and help with this one. But anyway, right now I'm running 0 camber all around, 0 toe in the rear, and 1 degree in the front. I am also running AE blue springs all around with 60wt oil. My front diff is tighened down pretty good, but it will still give a little. I did that in hope that it would help keep the front from pushing so bad and help pull it around the corners. I tighten down the rear diff though. It is almost locked.
I will get a more detailed description of my setup tomorrow, but like I said, I'm still trying to get it dialed in and drifting the way I like it. Once I find something that works good, I will let you know.
