RCU Forums - View Single Post - os .25 question.
Old 09-06-2006 | 06:40 AM
j.duncker's Avatar
j.duncker
Default RE: os .25 question.
Getting the compression ratio and plug right is the key to geting more power with more nitro.
You need a lower CR with more nitro and may need a cooler plug.
Add a head shim and play with different plugs. Guesstimate your airborne RPM and ground run with a smaller prop to achieve that RPM
You will not get massive increases 100 - 200 rpm. If anybody tells you they got 1000s then get the salt cellar out.
