Originally posted by mglavin
I also believe many user's have had problems with the application, installation and implementation of these servos. There have been situations where servo extensions, wyes, servo connectors, manufacturer specific RX signal degradation, power supplies and so fourth that have been thrown into the mix of the reported failures, all of which were the actual problem.
I completely agree with the above statement. While there are electronic component that can cause a servo to fail, there are also other factors. I have read on this board and others that a 5645 locked to one side only to have the same person post that the problem was solved and the Y-harness was the problem.
Mike.
