RCU Forums - View Single Post - Engine compression
Old 09-06-2006 | 02:05 PM
Jim Thomerson
Default RE: Engine compression
Well, sort of, more or less. If you are running castor oil, adding oil will add some more oil droplets which are incompressible and won't burn in your compression chamber. Sort of like adding bb's to your fuel ( bad analogy[&o]); takes up more space in the chamber and raises the compression ratio slightly.
