RCU Forums - View Single Post - Resolution
Thread: Resolution
Old 09-06-2006 | 07:31 PM
kregan's Avatar
kregan
Default RE: Resolution
Well Futaba seems to think I will not notice a differance?
Time will tell, as soon as my back is feeling better I will go
out and test.
Thanks for everyones help.
>Hi Advent,
>Reducing the travel by Dual rates will not reduce resolution enough
>to see with the naked eye. In fact with the plane in the air, you will
>notice no difference at all.
>I hope you find this information helpful. You can also reach our Futaba
>support technical team at 217-398-8970, or via fax at >217-398-7721.
>Sincerely,
>Krysta Hunt
>Product Development & Support Specialist
>Futaba Service Center USA
quote:
ORIGINAL: Advent
I have a question on system resolution.
After setting up a surface to travel thru its entire distance using 140% ATV
(in the end point adjustment screen), does reducing that travel by
DUAL RATES reduce its resolution?? Or does it only reduce travel.
Example:
Elevator.
End points set to 140 in both directions.
High rate set to 140% = 32 Degree's of movement up and down.
Low rate set to 65% = 15 degree's of movement up and down.
In the above example do I loose system resolution
on the Low rate setting?
Radio is a 9CAPSuper.
