Originally posted by glxvr6turbo
THanks for the pics I just got my cline regulator in mail today still waiting for the engine and the plane to arrive which should be jan 15, cant wait. What glow plug are you going to be using? And are you going to be using a starter (if yes than which one) or are you going to be hand starting it?
I am currently using an OS #8 but am told that the OS F plug is also good for this engine. The recommended method for starting this engine is a back-flip against compression. That will be my norm once the engine is properly broken in and readily starts. For now I am using a Sullivan Dynatron, connected to a 12volt Motorcycle battery -- it easily turns over the engine if you start with the prop up against compression.
