RE: Engine compression
Perhaps someone should ask whether the engine whose compression is in question is ringed or ABC. Ringed engines tend to have less compression than ABC engines, this is by design. Maybe if you fellas knew if it was ringed or ABC, you wouldn't have to speculate about the effects off putting extra oil in the fuel. Just my two cents.
