RE: Pull cable question
Good question on the Servo's. I haven't decided yet, I do believe I will use a standard size this time for Rudder and Elevator. I have have been using mini's in the Exceleron 50 (Hitech 425BB's), I had to modify the mounts for the shorter cases. In the past, pre Digital, High speed corless servo's were the choice of champions and I see no reason not to go with them now. That would be for Rud, Ail, and Elev. For the Throtle I haven't decided. I am going to look seriously into using a Hitech 65BB mini mounted in the cowl. CG measurements may influence that choice as well.
I could consider a perry pump and CG mount the Tank, but I think I'll stay with a forward tank since I won't be competeing with this, although I'll be flying it as if I were.
Lifesytle changes, family issues are preventing me from being active in pattern contests, that will have to wait awhile.
Well I'm beat, just finished up a 16 hour day.
Till next time.
Mike R
