RE: Engine compression
G'day Mate,
Be aware, that the more nitro and/or oil we use, the less methanol we're using, so we use a cool(er) plug. But the oil content will not increase you compression ratio. But in some engines, the manufacturers recomend a lower percentage of oil, than normal, one reason for this is because the fuel with a high oil content is slightly thicker & will not pass easily through the fuel system.
