RE: JR radio problem, Horizon's 'help'
Hi Martin
I am in OZ and we use the following receivers with our 2610(6102) and 9X (9303) radios (any JR radio) without any trouble at all:
Hitec single and dual conversion (hitec 555, RCD3500, electron range of receivers) basically any FM Hitec dual or single conversion rec.
Jeti Rex 7, Rex 5, and Rex 4. (The Rex 5 is a long range park reciever and the Rex 7 is full range) All single conversion and will work with any JR/graupner, Futaba or Hitec xtal. These are very good quality.
So I use JR radios exclusively and drive any brand of servo using the above receivers (and JR of Course). This is all OK when using PPM (FM) but is a different story when using PCM.
PCM usually requires like brand receivers.
I fly everything from gliders (aerotow, scale, electric and thermal) oldtimers, sport planes, scale and warbirds and never had any problems even at long long range.
Have not used any of the receivers you mention and never will. Use quality gear for quality results.
I hope this helps.
Cheers
Paul
