RCU Forums - View Single Post - HELI DIRECT LIED - HDX300 Main Gear with Strong Steel Main Shaft for Stock Blade CP
Old 09-07-2006 | 11:54 AM
duaneh1
Default RE: HELI DIRECT LIED - HDX300 Main Gear with Strong Steel Main Shaft for Stock Blade CP
The HD shaft that came with the main gear is too long and hole at top too small for the stock shear pin, but as others have said, its not an issue with pin made from paper clip or safety pin. it can stick out of bottom with no issues. However, their replacment shafts are the correct size and they come with a shear pin
