RCU Forums - View Single Post - 6s2p PARALLEL TAP SETUP
Old 09-07-2006 | 03:23 PM
mmc205's Avatar
mmc205
Default 6s2p PARALLEL TAP SETUP
Okay all, i have a few questions for the larger scale electric guys. What i'm planning on doing is making a 6s2p pack out of 4 3s1p 2200mah lipo packs. I'd like to charge them all at once, and keep them balanced. What i was thinking about doing is wiring all the same voltage taps in parallel, and using a blinky balancer. so in the end i would have a seven output tap with a (0v, 3.7v, 7.4v, 11.1v, 14.8v, 18.4v, 22.2v) My question is, would the cells wired in parallel using the taps self balance well enough during discharge to not overdrain one over the other. I'm pretty sure during charging (0.5-1.0C) they would. Attached is a schematic. Let me know what you think[img][/img]
