ORIGINAL: Fxrs_tim
I had to cut the cores as you suggested, so it's going to work out. Good thing I measured everything before finishing the wings up! Somehow my built-up wing ended up w/ 2 degrees of washin (not good) at each tip so I had to get a foam replacement. I still don't know how I got the twist, as everything measured out great before applying the sheeting. The wing was built on a jig, so I'm still scratching my head...
Tim
[/quote]
was it a built up wing then the first one? Because you said it was build in a jig.
erik
