RCU Forums - View Single Post - 4*40 Ailerons Trim
Old 09-07-2006 | 08:49 PM
pilotpete2's Avatar
pilotpete2
Default RE: 4*40 Ailerons Trim
Art,
That is not up trim, the APG when positioned as the directions indicate will give you the proper neutral aileron, no way you can set the neutral by the "TLAR" method. I've built the 4*40 way back when it was introduced, and my favorite plane now is my 4*60 with a Saito .65 on it, this is the only plane I have built that actually has the engine installed that's shown on the plans, just happened that way[8D], good luck with your 4*40, I'm sure you will enjoy it!
Pete
