RE: Major failure
The motor is definitely NOT mounted correctly. The mounting method used is causing tension on the crankcase and very likely caused the failure.
You must mount the motor to a flat surface. If the stanoffs were angled it wouldnt be such an issue but the standoffs are not angled causing the undesirable tension.
