BME 37% Ultimate
Hi all,
I am considering buying a BME Ultimate.
I'm not quite sure about the motor but thinking about a BME 115 with small canisters for noise reduction or maybe a DA 100. I would also like a smoke system so I need to know if there is room inside the plane.
What is the weight you guys end up with?
Servo setup? I am pretty sure I would use Hitec 5955s or JR 8611As with 2 on the rudder and one on everything else.
Anything I should know before stepping into the project?
Any suggestions are welcome!
Thank you.
