RCU Forums - View Single Post - TAMIYA PERSHING BUILD. NEED POINTERS
Old 09-08-2006 | 06:12 PM
edoubleaz's Avatar
edoubleaz
Default RE: TAMIYA PERSHING BUILD. NEED POINTERS
Only mod I made was the BYA idler upgrade. I had trouble initially with the tension of the tracks but the vaiable positions allowed by the new idler have ended all problems. I also took apart the speaker box to add room inside. A charging jack and Deans connectors are my next mods. Do all you can to reduce the spaghetti. If you get the Spektrum radio, it reduce the antenna and receiver space up front. Our new DAK member has figured out how to get both weapons to fire without adjusting trim tabs too. The front hatches are a perfect place to put the charging jack and we can get you some of that speaker cloth for under the engine deck if you want.
www.desertarmor.com
