RCU Forums - View Single Post - Major failure
Old 09-08-2006 | 06:20 PM
rmh's Avatar
rmh
Default RE: Major failure
You lost me on that one -
was that a positive statement ?
My comment about industrial was only meant to seperate typical model use from applications whre the engines are run for extended periods at full tilt - in frankly industrial applications .
Those of course create a lot of wear n tear in a much shorter time period and under more sustained loads than the model use
good or bad - it is just not the same .
