RE: JR radio problem, Horizon's 'help'
Perhaps this is a stupid question, but...All the receivers work just fine up to about ten feet with the antenna collapsed. That is all control surfaces work properly, all throws are set correctly and nothing buzzes or jitters. After ten feet kaboom, extreme servo movements on all channels, and if I continue to walk at about fifteen to twenty feet everything stops like there is absolutely no signal. With the antenna extended I can go about two hundred feet before the extreme jitters set in. Does this sound like a crystal problem? I'll be honest, I've been flying for a long time, but up until I bought this JR radio I never even touched the crystals. One tx for each plane. Thanks for you help guys.
Martin
Oh yeah, the GWS crystals were purchased with the rx's and were gws crystals. Same with the Mikro design it was purchased from them and they made no distinction about which radio brand it was for. The airtronics I bought a JR crystal on ch. 50.
