ORIGINAL: 50%plane
I believe the version I have is 3.00 Build 366. I think the very latest is Build 410. (but not an expert)
I tend to believe that the programming for G3 is not necessarily more complex but probably suffers from an older code base and a less modern architecture. It certainly appears to have been around much longer than many others
In that case, you should update before you pass full judgement on G3. The new update is .448. It is far more improved of the .300 or .366. In addition to much improved flight physics, you will be able to get user created planes(update .426) Photofields also came out about the version .366.(so you'll get them if you don't already have them...)
50%
How old is Build 366?
I find it tough to believe that after all the years of RF that the physics don't get great until the most recent version. Where can I can get the release notes? (I'll check the RF page)
